Rainer Köberl设计的奥地利BTV分公司办公大楼
2012-9-25 00:00| 发布者: ccbuild| 查看: 528| 评论: 0
简介:大楼底座的上方是三角形结构,表层覆盖有黑白相间的方块结构,形成棋盘样的效果,同时也能让人想起环绕因斯布鲁克的雪山。大楼负责人还专门为大楼外形设计举行了邀请赛,最终选定了这样的设计方案。设计师将屋顶建得 ...
大楼底座的上方是三角形结构,表层覆盖有黑白相间的方块结构,形成棋盘样的效果,同时也能让人想起环绕因斯布鲁克的雪山。大楼负责人还专门为大楼外形设计举行了邀请赛,最终选定了这样的设计方案。设计师将屋顶建得尽可能地高,以在周围环境中得到突出。大楼只有两层,外表黑白色方块是钢筋混凝土结构的,带有黑色气孔。表层后面的大楼主体也是钢筋混凝土结构,四周带有玻璃。在玻璃结构和外表层之间有一个60公分宽的阳台。圆形的窗能提供足够宽阔的视野,方形混凝土表层又恰到好处地保证了一定程度上的隐私性和透光度。下层是员工办公室、接待处和自助服务区,上面是会议室和小型阳台。最上面则分别出租给诊所和一个船运公司。办公楼周围各种设施齐全,非常便利。
The striking feature of this bank building is its steeply rising roof – Köberl wanted to make the building as tall as possible so it is not swamped by the surrounding urban architectural jumble. Actually, only two storeys are allowed in this location. That is why the body of the building bends sharply towards the roof ridge from the second storey upward. Underscoring the shape is the striking pattern of the facade. Like a chessboard, the outer skin consists of square, concrete-coloured panels made of fibre-reinforced concrete alternating with black air holes of the same size. In order to be better able to gauge the size of the individual panels, Köberl recounts, he went to Vaduz.There, Hans Jörg Göritz had realised a similarly steeply rising form of roof ending in a point for the Landesforum and Landesparlament (parliament) of the principality of Liechtenstein, though in this case of small-sized bricks.
英文名称:BTV branch
建筑设计:Rainer Köberl事务所
建筑地址:奥地利 因斯布鲁克
项目性质:办公楼
摄影师:Lukas Schaller
