Naf Architect事务所设计的艺术博物馆
2012-9-25 00:00| 发布者: ccbuild| 查看: 450| 评论: 0
简介:这个造型独特的艺术博物馆能给观者留下深刻的印象。建筑照明主要仰仗自然光,日光从天花板射进室内,穿过白色的柱状结构,形成间接光线,散发出柔和的光。墙壁缝隙照进的自然光反射在外面绿色区域。博物馆的混凝土墙 ...
这个造型独特的艺术博物馆能给观者留下深刻的印象。建筑照明主要仰仗自然光,日光从天花板射进室内,穿过白色的柱状结构,形成间接光线,散发出柔和的光。墙壁缝隙照进的自然光反射在外面绿色区域。博物馆的混凝土墙壁上分布着432块厚玻璃板,零星的光线就从这里玻璃板照进室内。不同程度、不同形状的光在博物馆内部交汇。由于对自然光线和空气流通情况的需求,博物馆造型采用了特殊的结构,以保证建筑拥有多处开口的同时还能保持稳固。建筑外形就像是经过多次折叠的纸张,拥有多个不规则的棱角和平面,立体感和艺术性十足。博物馆位于宁静的乡村,夜晚,博物馆内部的人工照明散发出光线,透过建筑表层的缝隙穿透到室外,照亮这片区域。现在馆是整个区域的地标性建筑。整个博物馆能最大程度地突出艺术品,为参观者提供良好的欣赏艺术品、体验各种深意的环境。
The works of Mr. Goami give striking image of various lights, thus, I decided to design the building focusing on natural light. Soft diffused light from top light, direct light pouring from top light through white cylinder for condensation of light spreading on the first floor, soft light from slits on the walls reflecting on the exterior green, fragments of graphical lights pouring through 432 plate glasses on the concrete walls; the space is filled with various kinds of lights. As an exhibition space, there was no need for structure such as columns and beams but as large wall as possible. The important factor of the museum was to incorporate natural light and wind, so corners are sliced with slits to the extent which would not interfere the exhibit. This idea would have left the building structurally fragile, so we studied a rational shape, which was structurally stable like folding one sheet of paper, origami, many time to make several corners, with models and three-dimensional structure analysis by computer.
建筑设计:Naf Architect & Design
建筑面积:9955平米
建筑地址:日本 广岛
项目性质:博物馆
