10 Design事务所设计的防龙卷风住宅
2012-8-13 00:00| 发布者: ccbuild| 查看: 501| 评论: 0
简介:这是由10 Design事务所设计的可以防龙卷风的住宅项目,它可以向乌龟缩到壳里一样在遇到大风袭击的时候蜷缩到地下去,一系列液压操纵杆可以将结构抬高或是降低,使住宅可以地上地下穿梭。光电板为住宅提供能量,同时 ...
这是由10 Design事务所设计的可以防龙卷风的住宅项目,它可以向乌龟缩到壳里一样在遇到大风袭击的时候蜷缩到地下去,一系列液压操纵杆可以将结构抬高或是降低,使住宅可以地上地下穿梭。光电板为住宅提供能量,同时还能利用空气中的污染重新生成燃料。住宅还有一个防水的密封系统,可以保护住宅免受暴风雨的袭击。这些住宅还能在遇到灾害时候发出警报,以提醒其他住宅。
Tornados would pose no threat to this conceptual house by architects 10 Design, which can tuck itself beneath the ground just like a turtle retracts its vulnerable head away from danger. A system of hydraulic levers would be used to push the moving structure up and down, out of a sunken dock beneath the ground. Photovoltaic cells on the exterior would provide energy to power the mechanisms, and maybe even harvest fuel from pollution in the air. When the house is secured for safety, a watertight seal would protect it from intense winds and thunderstorms. The architects envision entire communities of the houses, where any residence can sound an alarm to warn others of approaching tornados.
英文名称:Tornado Proof House
建筑设计:10 Design 事务所
项目性质:住宅
