heneghan peng事务所设计的埃及博物馆获奖方案
2012-8-10 00:00| 发布者: ccbuild| 查看: 521| 评论: 0
简介:这是由heneghan peng事务所设计并获得一等奖的埃及博物馆项目方案,这个项目的场地位于金字塔与开罗之间第一个沙漠高原的边缘,它由50米高的落差,尼罗河向地中海延伸流动形成了这一落差,这是一种定义三千年埃及地 ...
这是由heneghan peng事务所设计并获得一等奖的埃及博物馆项目方案,这个项目的场地位于金字塔与开罗之间第一个沙漠高原的边缘,它由50米高的落差,尼罗河向地中海延伸流动形成了这一落差,这是一种定义三千年埃及地形的地理状态。金字塔,埋葬纪念馆等都位于沙漠之上,离博物馆大概两千米远,博物馆的场地则既包含山谷也包含沙漠上的高原地区。设计利用层次的不同,打造新的高原边境,形成半透明的由石材定义的一层面纱,它白天晚上呈现出不同的形象。博物馆存在于尼罗河山谷与高原之间的层次里,但是不会延展超出高原平台。一系列从场地到三个金字塔的视觉轴线形成一个三维的结构,它定义了博物馆的框架,博物馆包含其中,从巨大的整体规模到精巧的细节。
The site for the Grand Egyptian Museum is located at the edge of the first desert plateau between the pyramids and Cairo. It is defined by a 50m level difference, created as the Nile carves its way through the desert to the Mediterranean, a geological condition that has shaped Egypt for over 3,000 years. The pyramids, funerary monuments, are located in the desert on the plateau 2km from the museum site, while the site for the museum is located both in the valley and on the plateau. The design of the museum utilizes the level difference to construct a new ‘edge’ to the plateau, a surface defined by a veil of translucent stone that transforms from day to night. The museum exists between the level of the Nile Valley and the plateau, never extending above the plateau. A 3-dimensional structure inscribed by a set of visual axes from the site to the three pyramids defines the framework within which the museum emerges, from the overall scale of the site to the smallest of details.
英文名称:The Grand Egyptian Museum
建筑设计:heneghan peng事务所
建筑地址:埃及 吉萨
建筑面积:100,000平方米
项目性质:博物馆
