Höweler + Yoon建筑事务所设计成都“空中庭院”
2012-10-29 00:00| 发布者: ccbuild| 查看: 549| 评论: 0
简介:“空中庭院”是一个20000平方英尺的会员制俱乐部,功能包括度假别墅、办公和一些娱乐设施,利用院落和坡屋顶的形式逻辑来组织功能,在有限的界限内嵌入了好几个庭院,并利用坡屋顶来调整院落间建筑的功能空间,从上 ...
“空中庭院”是一个20000平方英尺的会员制俱乐部,功能包括度假别墅、办公和一些娱乐设施,利用院落和坡屋顶的形式逻辑来组织功能,在有限的界限内嵌入了好几个庭院,并利用坡屋顶来调整院落间建筑的功能空间,从上方能看到所有的院落。这个综合体并未设置一个单独的中心,而是一系列小型中心空间的有机结合,多个庭院、多条路径、多重边界形成蛛网似的结构,这样的结果是创造了一系列多层次的外部空间,也就是“借景和透景”,从这个院落也许能透过游廊观赏到另一个院落的风景。这个综合体内部空间与外部空间的层次创造了丰富的空间序列。屋顶都采用向庭院内倾斜的形式,从侧面看上去高低错落的样子像是对山峰和峡谷的隐喻。主屋脊线的起伏倾斜使屋顶形态变化多样并扭曲了屋顶平面。为了维持屋檐同在一个水平面上,屋面都成了双曲线面,在贴材质的时候,用材质碎屑来填充缝隙以形成曲面的效果。建筑也利用了一些特殊材质来形成这些大尺度的建筑几何形态。
英文名称:Sky Courts /
建筑设计: Höweler + Yoon Architecture
项目地址: 中国 成都
竣工时间: 2012年
建筑面积: 20000 平方英尺
摄影师: Yihuai Hu
图片提供:Höweler + Yoon Architecture
Sky Courts is a 20,000 sqf corporate club house that incorporate short-term housing, office space, and entertainment facilities utilizing the logics of the courtyard and sloped roof. The project packs several courtyards into a defined perimeter and utilizes the sloped roof to accommodate program in the wedge between courtyards, allowing the project to read as 100% courtyard from above. The complex lacks a single center; instead it is a network with multiple centers, and multiple paths, edges and liners. The sequence through these precincts creates a series of layered spaces that line exterior spaces, and views from one courtyard might look through perimeter spaces and into other courtyards.The layering of interiors and exteriors creates a varied sequence through the complex. The roof geometry consists of a series of inward sloping roofs. The roof profile varies to create the impression of a landscape of peaks and valleys. The alternating inclinations of the major ridge lines produce a varied roofscape and cause the roof planes to twist. By maintaining a constant eave line and varying the perimeter, each plane on the roof is a hyperbolic ruled surface. The use of a ceramic tile uses the gap between units as well as the fine grain of the tile, to absorb the non planar roof condition. The ceramic tile, with a built in capacity to absorb tolerance between units aggregates to produce a twisting roofscape configuration. The project exploits a specific building material to achieve a larger geometrical effect.
