以色列K住宅
2012-9-29 00:00| 发布者: ccbuild| 查看: 499| 评论: 0
简介:从外表看,这栋住宅就是一个9米高的密闭混凝土结构,北面临街,两面表面几乎是不透光的。整个建筑是用预制混凝土板组成的,再加上结实的木制格子结构,看似相互矛盾的材料,为房间增添了东方气息和温馨感。住宅内部 ...
从外表看,这栋住宅就是一个9米高的密闭混凝土结构,北面临街,两面表面几乎是不透光的。整个建筑是用预制混凝土板组成的,再加上结实的木制格子结构,看似相互矛盾的材料,为房间增添了东方气息和温馨感。住宅内部装饰注重细节,细节处精致繁复。不同材料的和谐共融体现了房间设计者的独特心意,有利于让住户感受到宁静的感觉。
The design is a concrete block, 9 meters visible openings. The north elevation facing the street and both side facades seem completely opaque and yet they are not alienated to their environment. The entire structure is covered with a uniform system of prefabricated exposed concrete panels, which are integrated with heavy wood Latticework – A reminder to the traditional oriental element – the eastern trellis (“mashrabia”). The combination of materials and distribution arrangements add warmth, and ease the rigid system.
英文名称:House K
建筑设计:Auerbach Halevy Architects
建筑地址:以色列
项目性质:住宅
