MTF Proje事务所设计的亚达那市政厅和文化中心
2012-9-4 00:00| 发布者: ccbuild| 查看: 473| 评论: 0
简介:这是由MTF Proje事务所设计的位于土耳其亚达那的市政厅和文化中心项目,设计的基本思想围绕建筑的周围环境,这里到处都是绿色的背景,建筑有一半就是位于这绿色场地的地下,与地形连为一体。建筑的人类尺度也因此展 ...
这是由MTF Proje事务所设计的位于土耳其亚达那的市政厅和文化中心项目,设计的基本思想围绕建筑的周围环境,这里到处都是绿色的背景,建筑有一半就是位于这绿色场地的地下,与地形连为一体。建筑的人类尺度也因此展现。项目包含一个四层的市政厅,一个能容纳500人的文化中心,一个城市图书馆,一个婚礼堂,城市信息中心和工作室。建筑的内部根据功能和可持续性展开,鉴于当地炎热的气候,自然通风和照明被列为重点,以减少能量消耗。中庭空间将建筑一分为二,从而形成自然的院落空间。绿色屋顶更进一步减少了室内降温的能量需求。
The basic idea of the Adana City Hall and Cultural Center building by MTF Proje was based on the surrounding of the building, which is mostly captured with green areas. Half of the building is designed just under the green land which is coherent due to the topography. Here in Adana Çukurova, the building is designed due to the human scale. The building is consisted of a four story city hall, a culture center which has the capacity of nearly 500 people, a city library, a wedding place, city information center and the ateliers. The inside of the building is designed due to the function and the sustainability. Adana Çukurova has a hot climate. The natural air ventilation and the natural light is used in order to reduce the energy need. The atrium place divides the building into to two which helps the building work like a courtyard. The green roof also reduces the need of energy need for cooling the inner spaces.
英文名称:Adana City Hall and Cultural Center
建筑设计:MTF Proje事务所
建筑面积;17000平方米
场地面积:12900 平方米
建筑地址:土耳其 亚达那
