NAU事务所设计的捷克国家图书馆
2012-8-9 00:00| 发布者: ccbuild| 查看: 470| 评论: 0
简介:这是由NAU事务所和Holzer+Kobler事务所共同设计的捷克国家图书馆项目方案,项目融合捷克的文字历史,回顾过去,展望未来。建筑和空间的概念是由两个主要体量的互动生成的,一个是国家档案馆,一个是珍藏室,外立面的 ...
这是由NAU事务所和Holzer+Kobler事务所共同设计的捷克国家图书馆项目方案,项目融合捷克的文字历史,回顾过去,展望未来。建筑和空间的概念是由两个主要体量的互动生成的,一个是国家档案馆,一个是珍藏室,外立面的薄膜将包裹这两个元素,同时容纳公共的空间。国家档案馆位于图书馆中心,它立于岩床之上,浑然的塔楼旋转上升,朝着城市方向。作为对比,珍藏室则是一个两层的水平体量,好似一个装文书的盒子,漂浮在地面之上。公共设施则位于酒吧之上和之下。这些区域随着外立面的造型而呈现出持续的空间。
The National Library of the Czech Republic embodies the written heritage of the Czech culture, standing for its past, present and future. The architectural and spatial concept of the new library is generated through the interaction between the two main containers of the books – the National Archive and the Universal Collection – and the exterior membrane wrapping the two elements and housing all public spaces. The National Archive stands at the center of the library. Growing from the bedrock, the monolithic tower turns in an ascending movement toward the city of Prague. As a counterweight, the Universal Collection is housed in a two-storey horizontal volume, organized like a letter case, floating above the ground. The public facilities of the library are located below and above the bar. These areas are designed as a continuous space modulated by the external skin of the building.
英文名称:Czech National Library
建筑设计:NAU和Holzer+Kobler
建筑地址:捷克 布拉格
项目性质:图书馆
