Lecor办公楼 by Kjellgren Kaminsky Architecture
2016-2-13 20:03| 发布者: 新建筑| 查看: 148| 评论: 0 |来自: 网络
简介:“我们为钢铁制造商Lecor设计的新办公楼位于距哥德堡(Gothenburg)北10公里的孔艾尔夫(Kunglv)(瑞典)。Lecor 想将他们先进的钢铁制造加工技艺表现在他们自己的新办公楼上。这样我们便有机会在这里设计一座标新 ...
“我们为钢铁制造商Lecor设计的新办公楼位于距哥德堡(Gothenburg)北10公里的孔艾尔夫(Kunglv)(瑞典)。Lecor 想将他们先进的钢铁制造加工技艺表现在他们自己的新办公楼上。这样我们便有机会在这里设计一座标新立异的建筑作为地区的标志,并可使其可以从附近的告诉路上看到,于是这些便成为我们设计的出发点……”——Kjellgren Kaminsky Architecture
建筑最大的看点在于其被架起的钢桁架包括的混凝土盒子,盒子轻盈的架在主建筑之上,成为了一个良好的观景平台可以欣赏到孔艾尔夫森林的美景。
DESCRIPTION OF LECOR STEEL FACTORY
The building, which houses the Lecor headquarters includes offices, dining area/kitchenette, meeting rooms, a library and change-rooms.
GENERAL
We have worked with materials, colors and textures in various ways that can be associated with the steel industry and its traditions. The color pallet consists mostly of soft pastels and whites. We have adopted the principle of “draping” each room in a single colour.
OUTSIDE
The building is clad in dark gray steel panels in a repetitive pattern. To emphasize the factory function of steel production, we have allowed some elements of the building to shoot out of the facade in the form of a glass boxes, contained within a steel frame.
On the first floor, slides the main entrance as a windbreak with a pastel colored steel frame. On the second floor, adjacent to the staff kitchen/dining area, slides the “dining cube” in a clear yellow color.
On top, across the building, we further highlight and advertise the factorys’ steel operations by placing a conference room and an outdoor terrace enclosed in a long bridge of truss plant-steel construction. The lattice frame is metallic silver and the contained conference bridge is pastel green with large glass partitions along three of it’s sides. From this room you get a 270 degree view out towards the deep woods of Sweden.
INSIDE
Inside, the first floor of the building is divided into four main parts each with their own emphasised elements. The dining room at one end has the forest view, then there’s the change-rooms, the main entrance with a spectacular steel staircase and the office area with a stairwell of glass and steel as well as yellow polished steel “short cut” spiral staircase.
The entrance hall is similar to a white sea with a large staircase in the spotlight. It has a core of sturdy, tall, painted steel walls with a specially designed pattern resembling the white glow from welding, in the form of perforated holes of various sizes that will be lit both by artificial and the natural light of the above skylight. The walls of various heights extending up to the second floor combined with their powerful visual expression become the design elements of a worthy entrance for visitors and employees.
The entrance hall is lined with black ceramic tiles in order to contrast and emphasise the oak steps of the main stair and whiteness of the space in general. The black ceramic tiles are a mix of three sizes, presented in a specially designed pattern. This pattern continues outside the entrance hall itself, as a way to invite guests in.
We have selected certain places in order to mark them by “draping” them into a selected color. For example, the library on the second floor has a muted pink shade both on the carpet and the walls. The change-rooms, showers, toilets, and some pantries and kitchens are covered with pastel blue tiles, dull army green, pastel green, light grey, pale yellow and crisp white shades, following once more the principle that the whole room has a single color on the floor and walls.
On the second level hardwood flooring is used and has been layed in different directions depending on the room and it’s function and also to highlight the elements of the plan. The hardwood flooring is broken and contrasted at times, for example in the cloakroom and toilet by stark-white tiled floors and in the library by the pink carpet that stretches out into the corridor.
The walls of the office rooms are made of glass, the facing walls and doors have a soft gray tone. The “dining cube” has accent colors both inside and outside. Here a bright yellow tone is used internally on the walls and on the spiral staircase in combination with blue radiators. This is intended to create a bright, alert appearance at the building’s heart.
