建筑时空 › 首页 ›建筑论文› 装饰装修 › 查看内容
幕墙配件名词中英文对照
2014-2-21 09:49| 发布者: ccbuild| 查看: 381| 评论: 0
摘要: 1.30mm厚石材:30mm T.Stone 2.镀锌预埋件:Embed Galvanized castin 3.气密封胶条:EPDM Air vapour Gasket 4.M8*90不锈钢螺栓:M8*90 Stainless steel bolt 5.铝合金母型材:Female ...
3.气密封胶条:EPDM Air & vapour Gasket
5.铝合金母型材:Female mullion extrusion
6.镀锌连接件:Galvanized steel angle
7.M16*60特制:螺栓:M16*60 Special bolt
8.铝合金公型材:Male mullion extrusion
9.L50*5镀锌角钢:50*5 Galvanized steel angle
10.8*16 双组分结构胶:8*16 Structural sealant
11.1.5mm厚镀锌钢板:1.5mm Galvanized steel sheet
12.50mm保温棉:50mm Thermal insulation
13.100mm厚防火棉:100mm Fire thermal insulation
14.8+12A+6双银钢化夹胶玻璃:8+12A+6 Double Low-E IGU
15.不锈钢连接件:S.S bracket
16.铝合金百叶:(遮阳、装饰等这一类):Alum.louver
17.不锈钢自攻螺丝:S.S self screw
18.150*40*4铝方管:150*40*4 Alum.pipe
19.5mm厚U形槽:5mm Channel steel
20.8mm透明钢化玻璃:8mm Tempered glass
21.槽式预埋件:Embed Galvanized castin
22.平齐式锚栓:(背栓式石材用的):FZP.
23.隔热条:Thermal Break
