建筑时空 › 首页 › 建筑作品› 商业建筑 › 查看内容
芬兰:艺术休息居所
2013-8-15 20:00| 发布者: ccbuild| 查看: 357| 评论: 0
简介:  这座小舍建造在Finnish Fine Artist区域内,它是专为特邀艺术家打造的一个有生气的办公空间。小舍与芬兰当地的气候相协调,沉浸于芬兰浓厚的文化氛围之内,其功用和建造方针都是根据艺术家的要求建造而成。 ...
  小舍的形状就是一个八边形的一角。这样可以增加建筑前后的空间大小,从而打造出一个实用的立方体空间,在小舍内部较高的空间内有个小阁楼,这里可以工人们休息,中间是工作空间,下面是户外平台。
  Designed to be located on the property of a Finnish Fine Artist, this house is a live-work space for a guest artist. The form was generated from local climate, Finnish culture, and functions/guidelines provided by the Artist.
  The sectional shape is a quarter of an octagon. It increases in size from building front to back creating a utility cube with sleeping loft above at the higher end, a work space in the middle and an outdoor terrace at the lower end.
  编译:美讯在线-建筑中国网
