2014世界杯终级赛事场馆
2012-8-7 00:00| 发布者: ccbuild| 查看: 420| 评论: 0
简介:这是由Fernandes Arquitetos Associados事务所设计的位于巴西里约热内卢的2014年世界杯终级赛事场馆项目,这个场馆的设计会给人一种类似于马拉卡纳大球场一样的延续性,一旦进入到公共空间区域,新旧就共同融合,营 ...
这是由Fernandes Arquitetos Associados事务所设计的位于巴西里约热内卢的2014年世界杯终级赛事场馆项目,这个场馆的设计会给人一种类似于马拉卡纳大球场一样的延续性,一旦进入到公共空间区域,新旧就共同融合,营造出一种现代且熟悉的感觉及样子。设计的绝妙之处发生在座位席处,它展示出整个由原有结构切割出去的新建筑。表皮被保留,保证了从外面看,马拉卡纳大球场好像没人动过似的。屋顶是设计新引入的元素,但是不会造成任何视觉上的阻挡。
The design for the 2014 World Cup Final Stage Stadium by Fernandes Arquitetos Associados will provide a feeling of continuity as if the Maracanã, which is the original conception of the Journalist Mario Filho stadium, has scarcely changed. Once inside the main public areas, the old and the new will work together to create a modern yet familiar look and feel. The pinnacle of which occurs upon reaching the stands, revealing an entirely new stadium carved out of the original. The facade will be preserved, ensuring that, from the outside, the Maracanã appears almost untouched. The roof is one of the main new elements introduced, but will not bring any visual impact as it will not be visible from the outside.
英文名称:2014 World Cup Final Stage Stadium
建筑设计:Fernandes Arquitetos Associados
建筑地址:巴西 里约热内卢
项目状态:2013预计完成
