建筑时空 首页 建筑业界 行业聚焦 查看内容
自由之椅,给被设计所困的肢躯松绑
2013-9-5 19:43| 发布者: ccbuild| 查看: 40| 评论: 0
摘要: THE FREEDOM TASK CHAIR Winner of 10 international design awards for its many unparalleled revolutionary features Freedom is the highest standard by which other task chairs are judged. Movement is ...
THE FREEDOM TASK CHAIR Winner of 10 international design awards for its many unparalleled revolutionary features Freedom is the highest standard by which other task chairs are judged. Movement is essential for a healthy body which shouldn’t be constricted by locking mechanisms and manual controls. Freedom gives the maximum ergonomic benefit with the minimum number of manually adjusted controls. When fitted correctly to your body, no further adjustments are required. The Dual Pivot backrest automatically adapts to the changing needs of your spine. In other words, sitting comfortably isn’t something you should have to think about. The Greenguard-Certified Freedom chair contains 62% recycled material and is 90% recyclable. Can be customed upholstered to suit any interior setting. 自由之椅 是10个国际设计大奖的得主,且具有诸多优异的革命性功能。 自由舒适是评判工作用椅最高的标准。 健康的身体是可以自由运动,而不应该由机器设施和手动控制束缚。 自由是在受到最小控制的情况下,给人带来符合人体工程学的最大舒适度。 当它和你的身体结构完全吻合的时候,不需要进一步的调整。 双枢轴靠背会自动调节来适应你脊椎的不断变化。 换句话说,坐的舒适与否,并不是你必须应该思考的问题。 环保指南认证的自由椅包含有62%的回收材料和它本身有90%部分是可回收利用的。 可以定制,以配合任何室内布置。 Kelly Tian- 86- 18 62 153 8849 Kelly.tian@ani-imc.com
