建筑时空 首页 建筑业界 行业聚焦 查看内容
想不到的豪华浴室用品 国外浴室闪亮登场(下)
2013-9-5 11:33| 发布者: ccbuild| 查看: 56| 评论: 0
摘要: Shower Arch Enjoy a wall-to-wall shower experience with Hansgrohe's Pharo ShowerArc. Mounted diagonally or between two walls, this new form of shower system combines a gentle "rain" shower dire ...
Shower Arch
Enjoy a wall-to-wall shower experience with Hansgrohe's Pharo ShowerArc. Mounted diagonally or between two walls, this new form of shower system combines a gentle "rain" shower directly overhead, a separate hand shower, and six opposing body sprays along its U-shape water-carrying pipe. Specify side sprays with mist, aerated, or massage jets.
淋浴拱门
用hansgrohe的pharo showerarc来享受墙对墙的淋浴体验。展开角之间或两堵墙之间,这种新形式的淋浴系统结合了温和的“雨”淋浴,一个单独的手柄淋浴,对身体喷雾剂沿U形水从六面进管道。指定方喷雾剂有薄雾,曝气,或按摩喷射。
[page]
Radiant Floor Heating
One of today's hottest amenities, radiant floor heating systems are cozy, energy-efficient, and maintenance-free. Warmly Yours sells bathroom heating kits for rooms from 10.5 to 45 square feet. Each contains 15-watt/square foot TempZone electric elements sewn to fiberglass mesh less than 1/8 inch thick -- ideal for use under tile, stone, or hardwood. Control heat output with a timer or programmable thermostat.
地板辐射采暖
当今最热门的地板辐射采暖系统之一的是舒适,节能,和全免维修费用辐射地板。热销的浴室暖气包客从10.5至45平方英尺。每个所包含的15瓦一平方脚温地带,电流缩减为不少于1 / 8英寸厚的,以玻璃纤维为主要元素的网格-理想状态下使用瓷砖,石材,或硬木。控制热输出与定时器或可编程恒温器。
Hammered Copper Sink
Natural materials and fine craftsmanship elevate bathroom design. Witness the Maestro collection of vessel, or above-counter, basins from Native Trails. Hand-hammered from 15-gauge copper, each sink's tempered finish develops a rustic patina over time. One of four models, the Round Vessel (shown, $545 to $675) measures 16 inches across and 6.5 inches deep.
打铜水槽
天然材料和精细工艺提高浴室的设计。观察大师们收集的容器,或柜台面,本地生产的脸盆。手打从15针铜,每个调节好的水槽的完成在一段时间内开发了古朴的绿金秀。四种模型之一,圆圆的容器(标价545美元到675美元 )的尺度是16英寸长和六点五英寸深。
[page]
Steam Shower Module
From Lasco Bathware's new Contours brand, the Radius series adopts the concave surfaces and pearlescent finishes of sports cars. Acrylic shower modules in 48- and 60-inch widths offer 17 colors, optional steam and body-spray systems, aromatherapy, eight-color chromatherapy lighting, and a spa-style teak floor insert. Relaxing steam packages include preplumbed generators and electronic display panels.
蒸汽淋浴模块
lasco 洗澡盆新轮廓的品牌,半径系列采用凹表面和珠光饰面的跑车。压克力淋浴模块在48和60英寸的宽度之间,有17种颜色,可选的蒸汽和身体喷雾系统,芳香疗法,八色医光疗法照明,以及水疗式的柚木地板插入。放宽蒸汽软件包包括preplumbed发电机和电子显示屏。
Foot Spa
Many people believe the ultimate luxury is feet that feel good. MTI Whirlpools makes that easy with its JentlePed cast-acrylic foot spa (from $820). The mini whirlpool uses heat, four massage jets, and a raised exercise bar in the angled floor to relieve sore spots and rejuvenate tired feet.
足部水疗中心
许多人认为最终的奢侈品是以脚的良好感觉来衡量的。MTI漩涡,使投掷压克力容易与jentleped的足部水疗中心(820美元起)配合。小漩涡利用热四按摩喉,在直角楼安装体验吧,以舒缓酸痛点和振兴疲惫的双脚。
[page]
Mixed-Media Fixtures
Stainless steel in the bathroom is already novel, but Neo-Metro's Cerine suite can now be customized with water-resistant leather insets. As shown, the toilet costs $3,600; the vanity costs $5,350. Other options: a vessel sink, copper-finish fixtures, and insets of cherry, mahogany, bamboo, or any material you feel reflects your personal style.
混合媒体装置
不锈钢在浴室已算是比较新奇的了,但新地铁的纯地蜡套房,现在可以定制的耐水皮革插图 。如表所示,厕所的费用3600美元;浮华装置值5350美元。其它选项:一个污水槽容器,铜制设备,配套樱花,桃花心木,竹条,材料等,或者任何你觉得可以反映您风格的材料。
