建筑时空 首页 建筑业界 行业聚焦 查看内容
国外22个最富创意的浴室存储空间 浴室大享受
2013-9-5 11:26| 发布者: ccbuild| 查看: 49| 评论: 0
摘要: Soak It Up Problem: There is no space to store bath essentials. Solution: Put the space around the tub to work. Tilt-out bins with recessed panel doors store towels, bubble bath, bath salts, sh ...
Soak It Up
Solution: Put the space around the tub to work. Tilt-out bins with recessed panel doors store towels, bubble bath, bath salts, shampoo, and conditioner. These products stay hidden until its time to relax.
浸泡起来
问题:没有空间来存储洗浴必需品。
解决方法:把浴缸周围的空间利用起来。倾斜了回收箱,打开小侧门存储毛巾,泡沫浴,沐浴盐,洗发水,和空调。这些物品平常就隐藏在这里,用到它们的时候就拿出来放松一下。
Warm Up with Wood
Problem: Your bathroom has no closet.
Solution: If you have the space, a freestanding cabinet is your best stand-in for a closet. Look for unfinished cabinetry at home centers, or snag a great piece at a yard sale. Consider cabinets intended for other purposes, such as this repainted safe.
用木头热身
问题:您的浴室没有壁橱。
解决方法:如果您有空间,一个独立的橱柜对于一个小房间来说是最好的选择。在家里的中心位置看看还有没有没塞满的橱柜,或者把它以一个高价钱卖掉。有意将橱柜用于其他目的,比如重新画一个保险箱。
[page]
Find Lost Space
Problem: You don't have floor space for shelves.
Solution: Gain storage without losing space by building shelves right into the walls between studs. An unused area above the tub and adjacent to the sink fitted with simple glass shelves offers ample space for towels and accessories.
寻找失去的空间
问题:你没有空间放架子。
解决方法:在不缩小空间的前提下获得更多的存储空间,可以采取在墙上用钉子固定架子的方法。浴缸上未使用的面积和毗邻水槽的配备简单的玻璃货架上提供了充裕的空间,毛巾及配件。
Shelve Your Problems
Problem: Your shelving doesn't match your needs.
Solution: Remove that past-its-prime plastic shelving system and replace it with wood or rubber-coated wire systems. or take matters into your own hands and build new shelves with 1x12 painted pine boards as shown here.
您的问题暂时搁置
问题:您的搁置不符合您的需要。
解决方法:拆除过去塑料架子系统并且用木头或橡皮线系统来代替。或采取事宜纳入自己的双手建立新的货架,材质选用所显示的这种1x12松木板。
[page]
Show and Stow
Problem: You lack versatile space.
Solution: Keep all those hardworking bath essentials hidden yet handy in this cottage-style wall unit. Use display space for colorful and attractive items and stow away the more homely basics.
展示和收藏
问题:你缺乏灵活的空间。
解决方法:保存所有这些勤劳工作的沐浴必需品,但把这些隐藏在这方便的平房式的墙里。使用显示的空间,用丰富多彩的和有吸引力的东西,把那些更家常的基本物品拿走。
Try Something Different
Problem: You find only the same old storage options at all the discount stores and home centers.
Solution: There are many different ways to store your bathroom stuff if you think creatively. Here, a wood desktop organizer from an office-supply store, painted pale blue to match the walls, tops a freestanding linen cabinet.
试着用一些不同的东西
问题:您在在所有折扣零售店及家居中心找到的只是一成不变的老的存储物品。
解决方法:如果你富有创作性的话,有许多不同的方式来存储您的浴室的东西。这里,一个从供应商店买来的木头电脑桌,为跟墙面搭配图上淡蓝色,整体成为一个独立的亚麻橱柜。
[page]
Light Up Your Bath
Problem: Your bath is dark and uninviting.
Solution: Install a wall sconce inside your linen closet or storage cabinet. Creamy eggshell finish offers a clean, simple background.
使你的浴室容光焕发
问题:你的浴室是昏暗和没有吸引力的。
解决方法:在你的壁橱或者存储的柜橱里装置一个墙面突出的烛台。奶油蛋壳可以提供一个清洁,简单的背景。
Highlight a Niche Display
Problem: Special keepsakes are put away in boxes.
Solution: A fluorescent uplight fixture in a display niche or atop a cabinet can provide timeless style and helpful illumination.
突出壁龛的展示
问题:盒子里收满了纪念品。
解决方法:在一个展示的壁龛里摆放荧光照明灯具,橱柜顶上可以提供无限风格和有用的照明。
[page]
Divide and Conquer
Problem: Small storage spaces lack creative inspiration.
Solution: A simple, divided plywood box covered in newsprint tells the story of creative storage. Petite jars and boxes make the most of otherwise limited storage areas.
分步解决
问题:存储空间小,缺乏创作灵感。
解决方法:一则简单的分割在不同豆腐块的新闻讲述了一个创造性存储的故事,迷你罐和盒子使大多数有限存储的空间变大。
Flex Your Storage
Problem: You rent, but you still want stylish bathroom storage.
Solution: Look for TV trays, baskets, wall hooks, collapsible chairs, and lightweight wall containers in discount stores. For a quick punch of style, forget about paint, and rely on vividly colored towels and rugs.
伸缩你的存储
问题:你的租金,但你还是要时尚浴室储存。
解决方法:在折价商店看电视盘,篓,壁钩,折叠椅,轻墙容器。保持迅速的作风,忘记油漆,忘记依靠彩色毛巾和地毯使浴室生动。
Brighten Your Bath
Problem: Your bathroom is boring.
Solution: Here, chrome and clear storage accessories brighten the bathroom. For a fast dash of flash, top a dark countertop with a piece of hammered-aluminum sheet metal, available at home centers. Cut the metal to the size you need, then use flat-nose pliers to fold under 1/2 inch of the metal sheet on all exposed edges.
使浴室生辉
问题:你的浴室是乏味的。
解决方法:这里,用铬钢和明亮的存储配件照亮浴室。为了飞速闪亮的效果,在昏暗的厨房工作台面装上一个用金属做成的铝片,使它能在家的中心照明。削减金属的大小满足你的需要,然后使用单位鼻钳子折叠下在所有可能暴露的边缘的1 / 2英寸金属薄板。
