建筑时空 首页 建筑业界 行业聚焦 查看内容
08卫浴世界流行风 18图秀国外小浴室巧妙设计
2013-9-5 11:03| 发布者: ccbuild| 查看: 69| 评论: 0
摘要: Pearly Whites Deep-hued sinks, toilets, and tubs can look dramatic in a large bath,but induce claustrophobia in a small one. Go with classic white and express your sense of style with the desig ...
Pearly Whites
Deep-hued sinks, toilets, and tubs can look dramatic in a large bath,but induce claustrophobia in a small one. Go with classic white and express your sense of style with the design of the fixtures.
珍珠白
在一个巨大的卫生间,深色调的水池,厕所,洗澡盆看上去非常有戏剧效果,但在一个小的卫生间就会有一种对寂闭著的场所的恐怖症。用经典的白色表达你对摆设的设计感觉和风格。
Slide, Don't Swing
Trade a standard door for a sliding pocket door to gain additional floor space once reserved for the door swing. Bifold doors (doors that fold up like a screen) can also save space.
滑,不摆动
将标准的门当作一个滑动的口袋来对待,这样可以获得额外的楼面面积,还可以让门在预留的空间运动自如。两褶门(大门倍,像一个屏幕)也可以节省空间。
[page]
Bright Lights
Small spaces call for good lighting to avoid feeling cramped and depressing. It's doubly important in bathrooms where shaving and applying makeup require strong light. So don't skimp on light fixtures. Instead, consider using both wall-mounted sconces and ceiling-hung fixtures. Remember, windows provide natural light, which is an easy and inexpensive way to open up a small room.
明亮的光线
狭小空间的要求良好的照明,以避免拥挤和沮丧的感觉。需要强化线这点在修面和化妆间具有双重作用。所以不要忽略了灯具。相反,考虑利用这两个挂墙烛台和天花板吊顶。记住,窗户可以透进自然的光线,这是点亮一个小房间的容易和便宜的方式。
Glass Shelves
Glass shelves increase the room's sense of space because they can sometimes appear invisible. Items placed on them seem to hover in air, which gives a much lighter effect in a small space than heavy cabinetry can provide.
玻璃货架
玻璃的货架上增加房间的空间感,因为他们可以有时似乎无形。东西摆在上面就像悬空一样,这在小空间内会比细木家具提供的效果轻很多。
[page]
Up on a Pedestal
A pedestal sink is a great way to open up a small bath because it eliminates the space-hogging vanity. The downside to a pedestal sink is that it doesn't allow for much storage. However, adding a small ledge above the sink, like the tile ledge here, creates room to store bathroom essentials.
成立于基座
下沉的基座是打开小浴室的伟大方式,它消除了空间贪婪者的虚荣心。一个台阶下沉的缺点是不能有更多的储存。但是,加入一个小岩壁之上,梳妆台,像瓷砖壁架在这里,创造的空间来存储浴室必需品。
Hide-and-Sink
Give guests more space to move around in a powder room by tucking the sink into a drawer that slides in and out of the wall. Now, the sink only takes up space when it's needed.
隐藏的和沟槽
为了给客人更多的空间来走动,在墙壁的卷起处设计一个推拉抽屉,现在,下沉的地方只在需要的时候才会占据空间。
[page]
Take a Neutral Stance
Because pale and cool colors reflect light, soft whites, pastels, and neutrals can make a bath feel bigger. Woodwork, trim, and doors will "disappear" if they are painted the same hue as the walls. The effect is enhanced if cabinets and counters are the same color as the walls.
采取暗灰的色调
因为苍白和冷静的颜色反映光,软白, 粉蜡笔和暗灰可以使得浴室感觉上更大一些。可以洗澡,觉得更大。木工,装饰,门会“消失”如果他们是画色彩,同时作为墙壁。效果是提高了,如果机柜和柜台是以相同的颜色作为墙壁。
Lead the Eye Upward
Make a ceiling look taller with some visual tricks. A vertical stripe on the walls can give the illusion of a higher ceiling. Wood moldings, wallpaper borders, and tile designs placed where the walls and ceiling
meet will also provide a splash of color and help naturally draw the eye upward.
引导眼睛向上
利用一些可视化的手法让天花板看起来更高一些。一个纵向条纹的墙壁上能给予天花板更高的幻想。
木材成型品,壁纸边界,瓷砖的设计,这些墙壁和天花板需要的地方还将提供一个醒目的颜色和帮助,自然引起眼睛向上。
[page]
Treat Windows Simply
No matter what their size or style, windows help enlarge the feel of a room if they're allowed to transmit light. If possible, leave windows unadorned with clear or frosted glass.
窗户的设计要简单
不管其规模大小或样式, 窗户只要允许传递光都会帮助一个房间的放大感觉。如果可能的话,尽量不要装饰窗户,就用清晰的或磨砂的玻璃。
Take a Reflective Look
Mirrors stretch space by reproducing it. Mirroring the long wall of a narrow bath, for example, can change the room's proportions and make it seem wider. Be sure to place mirrors so they reflect the bath's assets-- whether that's a wall hanging, a panoramic view, or the widest room angle. Two mirrors positioned opposite each other create the illusion of a never-ending room.
采取反射看看
重复利用镜子可以舒展空间。在狭窄的浴室墙壁上装一面镜子,举例来说,可以改变房间的比例,使它看上去更宽广。记得安装个镜子,它们可以反射浴室的装置,无论是墙上悬挂,全景,或广泛的房间角落。
[page]
Put Clutter in Its Place
In a small bath, space is too precious to be taken up by clutter. Pare down your bath countertop to the things you really like or need to have handy, then store the rest. Customize your closets and cupboards with wire racks, bins, and shelves.
把杂乱物放在它该放的位置
在小的浴室里,空间弥足珍贵所以应摆放整齐。削减您放到浴室里的厨房桌上的东西,如果你真的很喜欢或需要就储存在剩余的空间。自定义您的衣柜和橱柜与钢丝衣架,垃圾桶,和货架。
Let the Sun Shine In
Clear glass is the best option to expand space. It lets you see into a shower, making the room feel bigger. Look too, for window designs to welcome sunlight yet protect privacy. Skylights, clerestory windows, and glass block are all options that maintain privacy.
让阳光照耀进来
清晰的玻璃是扩大空间的最好选择。它可以让您看到一个淋浴,使空间感觉更大。同样,也要设计好窗口可以透进更多阳光但也要保护隐私。
[page]
Streamline Storage
For a sleek, clean look, keep storage flush with walls whenever possible. Narrow, built-in shelving, such as between wall studs, can easily corral collectibles -- from picture frames to perfume bottles.
简化存储
每当可能的时候,为光滑的,清洁的外观,保持存储就要冲洗墙壁。狭窄,内置在墙壁上的,如之间的墙钉,可以轻易地围栏收藏品-从画框到香水瓶。
Put on a Floor Show
Maintaining an unbroken sweep of floor is a good way to stretch visual space. But bulky components can make this a difficult task. If possible, use pedestal or console sinks rather than a vanity.
到上面的楼层看
保持完整的打扫地板是一个延伸视觉空间的好方法。但体积大的组件可以完成这一项艰巨的任务。如果可能,请使用底座或控制台汇,而不是虚幻的东西。
[page]
Scale Down Fixtures
Replace space-stealing fixtures with smaller versions, like these scaled-down wall-mounted sinks. You'll also find small basins or slim-and-trim pedestal sinks designed especially for small baths.
缩减固定物
用较小版本的缩小空间的固定物来取代,就像这些小挂墙汇。您也可以找到小盆或者苗条的专门为小浴室设计的基架。
Hide Storage Space
Stylish sink skirting provides hidden storage space for ugly bathroom necessities. Cut the fabric to the desired width and length, then attach with simple hook-and-loop tape.
隐藏的存储空间
时尚的接收端为丑陋的浴室必需品提供隐藏的存储空间。以所期望的宽度和长度来削减织物,然后附上简单的钩和闭环磁带。
Adopt Zen Thinking
Leave only what you absolutely need in a small bathroom: a few hand towels, a bar of soap, and extra toilet paper stashed away in a slim storage unit. A pedestal sink saves space and is a showstopper in marble.
采取禅宗思想
只留下你绝对需要的小浴室:手巾,一盒香皂,额外的手纸,把这些储藏在狭小的空间里。基座下沉可以节省空间,而且在大理石里绝对让你惊喜。
