建筑时空 › 首页 › 建筑业界› 建筑材料 › 查看内容
绝缘--是在住房节能中玻璃窗面临的关键
2001-6-25 00:00| 发布者: ccbuild| 查看: 563| 评论: 0
简介:n the wake of President Bush’s national energy policy unveiled yesterday, consumers across the country are taking a second look at energy efficiency in the home. According to the National Associatio ...
n the wake of President Bush’s national energy policy unveiled yesterday, consumers across the country are taking a second look at energy efficiency in the home. According to the National Association of Home Builders (NAHB) and the NAHB Research Center, home buyers can ensure they are getting the most energy efficiency for their dollar by asking the right questions about products and building materials. Consumers should inquire about the availability of the following features when they shop for a new home, or upgrade their existing home’s energy efficiency:
Check for the appropriate amount of insulation for your climate in the walls, roof assembly, and floor;
Look for high-performance, double-pane windows that have high-performance (e.g., low-e coated or solar control spectrally selective) glass that helps reduce heat loss in the winter and heat gain in the summer;
Ask for highly efficient heating and cooling equipment. Nearly 50 percent of a typical home’s utility bill goes toward heating and cooling;
Choose energy-efficient appliances and lighting by checking the appliance’s EnergyGuide label; this label will provide an estimate of the unit’s annual operating costs;
In some parts of the country, consumers can consider using the sun’s energy to help reduce utility bills via solar water heaters that can meet a home’s hot water needs and photovoltaic (PV) systems that can convert sunlight into electricity;
Use hot water wisely, by turning down the water heater’s thermostat setting to 115 from 120 degrees Fahrenheit; buying an energy-efficient water heater; installing non-aerating, low-flow faucets and showerheads; using the “warm” water setting on the clothes washer instead of the “hot” water setting; and setting the dishwasher to “energy saver” or “water saver”;
Check to ensure that the house is well sealed against air leakage. In some areas of the country, as much as 30 to 40 percent of a home’s energy load can be attributed to the leakage of outside air into the home.
