建筑时空 首页 建筑论文 给排水论文 查看内容
高层建筑二次供水水质调查
2008-3-1 12:53| 发布者: ccbuild| 查看: 346| 评论: 0
摘要: 简介: ①目的 了解高层建筑二次加压供水水质状况。②方法 采取22处高层建筑二次加压供水水样,分别测定细菌总数、总大肠菌群数、余氯及氨氮等指标,并与一般水网水样检测结果进行比较。③结果 冬春季及夏秋季二次 ...
简介: ①目的 了解高层建筑二次加压供水水质状况。②方法 采取22处高层建筑二次加压供水水样,分别测定细菌总数、总大肠菌群数、余氯及氨氮等指标,并与一般水网水样检测结果进行比较。③结果 冬春季及夏秋季二次供水水样中的细菌总数、总大肠菌群数及氨氮含量均高于同期一般水网水样,差异有显著性(t=2.57~28.62,P<0.05,0.01);余氯含量低于同期一般水网水样,差异有显著性(t=24.50~31.58,P<0.01)。
关键字:二次供水 水污染 水质调查
中国图书馆分类法分类号
R123.5 INVESTIGATION OF WATER QUALITY FROM SECONDARY WATER SUPPLY SYSTEM OF HIGH BUILDINGS Wang Qiuzhen, Zhang Chaoying, Lu Xiaoqing Department of Preventive Medicine, Qingdao Medical College, Qingdao 266021
【ABSTRACT】 Objective To find out water quality of secondary water supply system of high buildings. Methods Sampling water was taken from sencondary water supply system. Total bacterial count, total coliform group, residual chlorine and ammonia nitrogen were detected respectively. Results Total bacterial count, total coliform group and ammonia nitrogen of water taken from secondary water supply system in Winter-Spring and Summer-Autumn were significantly higher than those from normal potable water(t=2.57-28.62,P<0.05,0.01) ; Residual chlorine was significantly lower than that of the normal drinking water(t=24.50-31.58,P<0.01). Total bacterial count, total coliform group and ammonia nitrogen of secondary water supply system in Summer-Autumn were significantly higher than those in Winter-Spring(t=2.24-24.72,P<0.05,0.01). Conclusion Water quality of secondary water supply system was worse than that of normal potable water.
【KEY WORDS】 secondary water supply; water pollution; disinfection
近年来,城市高层建筑日益增多,这些建筑多采用二次加压供水系统供水,其水质情况的好坏与居民的健康状况有直接的关系。为了解青岛市市区高层建筑二次供水的水质现状,我们于1997~1998年冬春季、夏秋季分别抽样调查了青岛市部分高层建筑二次供水系统的水质状况。现报告如下。
1 材料和方法
1.1 采样方法
以青岛市市区22处高层建筑二次供水系统水源作为检测对象,并随机抽取22处一般水网水样作为对照。 余氯含量及氨氮指标分析所用水样按一般水样采集方法采集。细菌总数和总大肠菌群数测定所用水样严格按照无菌操作的基本要求进行采样。为消除水样中余氯的继续作用,采样瓶中预先加入30g/L硫代硫酸钠溶液1mL.
1.2 测定方法
细菌总数、总大肠菌群数、余氯及氨氮含量按文献〔1〕方法进行测定。
1.3 统计学处理
检测结果以±s表示。细菌总数及总大肠菌群数的测定结果经平方根转换后,采用t检验进行组间比较。余氯、氨氮含量组间比较采用t检验。
2 结果
2.1 细菌总数的测定结果
冬春季、夏秋季二次供水水样中细菌总数均高于同期一般水网水样中细菌总数,差异均有显著意义(t=2.57,4.52,P<0.05,0.01)。夏秋季二次供水水样中细菌总数高于冬春季,差异有显著意义(t=2.29,P<0.05)。见表1.
表1 水样细菌测定结果(±s)
水样
4
