建筑时空 › 首页 ›建筑论文› 环保论文 › 查看内容
Shell side mass transfer in a trans
2007-12-10 16:50| 发布者: ccbuild| 查看: 289| 评论: 0
摘要: 简介: The free surface model was introduced to describe the shell side fluid flow in a transverse flow hollow fiber membrane contactor, and a new method was developed to calculate the shell side hyd ...
简介: The free surface model was introduced to describe the shell side fluid flow in a transverse flow hollow fiber membrane contactor, and a new method was developed to calculate the shell side hydraulic diameter, the effective average velocity, and the Reynolds number. An empirical shell side mass transfer correlation was presented for commercial Liqui-Cel? Extra-Flow contactors on the basis of the experimental data reported by Sengupta et al. The data were correlated very well with maximum discrepancies of ?10% between the predicted and observed results.
关键字:Membrane contactors;Mass transfer;Free surface mod
下载全文(PDF格式,英文版):Shell side mass transfer in a trans
更多
  • 我来说两句 ()
更多网友评论 »
