建筑时空 › 首页 ›建筑论文› 结构软件应用 › 查看内容
钢筋混凝土梁分析
2011-1-6 15:03| 发布者: ccbuild| 查看: 258| 评论: 0
摘要: /COM,ANSYS MEDIA REL. 60 (090601) REF. VERIF. MANUAL: REL. 60 /VERIFY,VM146 /PREP7 /TITLE, VM146, BENDING OF A REINFORCED CONCRETE BEAM C*** STR. OF MATL., TIMOSHENKO, PART 1, 3RD ED., PAGE ...
/VERIFY,VM146
/PREP7
C*** STR. OF MATL., TIMOSHENKO, PART 1, 3RD ED., PAGE 221
ANTYPE,STATIC
ET,1,SOLID65,,,,,2 ! REINFORCED CONCRETE SOLID ELEMENT
ET,2,LINK8 ! STEEL RODS
ET,3,PIPE16,,,,,,,1 ! DUMMY ELEMENTS FOR CONSTRAINT EQUATIONS
R,1
R,2,.15 ! HALF AREA OF ROD
R,3,1,.5 ! ARBITRARY CONSTANTS FOR DUMMY ELEMENTS
MP,EX,1,2E6 ! CONCRETE PROPERTIES
MP,NUXY,1,0
TB,CONCR,1
TBDATA,3,0.0,-1 ! ZERO TENSILE CRACKING STRENGTH
! REMOVE CRUSHING CAPABILITY
MP,EX,2,30E6 ! STEEL PROPERTIES
MP,NUXY,2,0.3
N,1
N,2,1.5
NGEN,5,2,1,2,1,,1.5
NGEN,2,10,1,10,1,,,5
E,7,8,10,9,17,18,20,19
TYPE,3 ! DEFINE DUMMY ELEMENTS FOR ROTZ DOF
REAL,3
E,10,8
E,20,18
EGEN,4,-2,1,3
TYPE,2 ! REINFORCING RODS AT THE BOTTOM SURFACE
MAT,2
REAL,2
E,1,2
E,11,12
CE,1,, 2,UX,-1, 6,UX,1, 6,ROTZ,3 ! CONSTRAINT EQUATION TO ENSURE
CE,2,,12,UX,-1,16,UX,1,16,ROTZ,3 ! PLANE SECTION REMAINS PLANE
CE,3,, 4,UX,-1, 6,UX,1, 6,ROTZ,1.5
CE,4,,14,UX,-1,16,UX,1,16,ROTZ,1.5
CE,5,, 8,UX,-1, 6,UX,1, 6,ROTZ,-1.5
CE,6,,18,UX,-1,16,UX,1,16,ROTZ,-1.5
CE,7,,10,UX,-1, 6,UX,1, 6,ROTZ,-3
CE,8,,20,UX,-1,16,UX,1,16,ROTZ,-3
NSEL,S,LOC,X
D,ALL,ALL ! FIX NODES IN Y-Z PLANE
NSEL,ALL
D,ALL,ROTY ! CONSTRAIN UNNEEDED PIPE ROTATIONS
F,6,MZ,300,,16,10 ! APPLY BENDING MOMENT
FINISH
/SOLU
AUTOTS,ON
NSUBST,5
OUTPR,,LAST
SOLVE
/POST1
ESEL,S,ELEM,,1,1
*GET,SCON,NODE,9,S,X
ESEL,S,ELEM,,13,13
ETAB,ST,LS,1
ESORT,ST
*GET,STL,SORT,,MAX
*status,parm
*DIM,LABEL,CHAR,2,2
*DIM,VALUE,,2,3
LABEL(1,1) = 'TSTR STL ','TSTR CON'
LABEL(1,2) = ' psi',' psi'
*VFILL,VALUE(1,1),DATA,387.28,-18.54
*VFILL,VALUE(1,2),DATA,STL,SCON
*VFILL,VALUE(1,3),DATA,ABS(STL/387.28),ABS(SCON/18.54)
/COM
/OUT,vm146,vrt
/COM,------------------- VM146 RESULTS COMPARISON --------------
/COM,
/COM, | TARGET | ANSYS | RATIO
/COM,
*VWRITE,LABEL(1,1),LABEL(1,2),VALUE(1,1),VALUE(1,2),VALUE(1,3)
(1X,A8,A8,' ',F12.2,' ',F12.2,' ',1F5.3)
/COM,-----------------------------------------------------------
/COM,
/COM,NOTE: THERE ARE VERIFIED RESULTS IN VM146 NOT CONTAINED IN
/COM,THIS TABLE
/OUT
FINISH
*LIST,vm146,vrt
